Activity Forums Maxon Cinema 4D Material on the convex edges (like worn edges)
  • Material on the convex edges (like worn edges)
    Posted by Arvin Bautista on December 29, 2010 at 10:40 pm
    I’ve looked for this for a good long time, but I still haven’t found it: anyone know how to create a procedural material that adds worn edges on the corners of a model? Something like the opposite of ambient occlusion, which adds to obscured edges, this would add material to the edges that stick out most.
    Arvin Bautista
    Greasy Pig Studios
    Los Angeles, CA
    https://www.greasypigstudios.com
    Brian Jones replied 15 years, 8 months ago 3 Members · 2 Replies
  • Adam Trachtenberg
    December 30, 2010 at 12:01 am
    Unfortunately I don’t know of anything that does that. I think the best you can do is apply AO to your object, reverse the polygon normals, and then bake the AO to a bitmap.
  • Brian Jones
    December 30, 2010 at 12:58 am
    you could also use Proximal with the object the material is on for a target as the layer mask in a Layer shader or in the Alpha channel if mixing more than one texture.
