Activity Forums Apple Final Cut Pro Legacy Material not consistent frame rate loaded from 1200a
  • Material not consistent frame rate loaded from 1200a
    Posted by Philip Owens on June 16, 2008 at 11:28 pm
    My assistant is loading material shot @ 24fps DVCPRO HD 720p using the Panasonic 1200a deck – this is material shot @ 24fps on the Varicam. We’ve had a problem in the past with editing material loaded at 59.94fps, in 23.98 timelines, so this time we are making absolutely certain that the material is loaded 720p24 @ 23.98fps. He starts by testing a few mins, settings on the deck set to factory default, and all is well. But he has disovered that if his clips are longer than ~9mins, the material switches from 23.98 to 59.94. WTF? Basically, with the same piece of material on tape, no camera cuts, if he digitises an 8 min chunk, it comes in 720p60 @ 23.98fps. If he stretches it to 10mins, it has become 720p60 @ 59.94. What is going on?
    FCP 6.0.3 on Quad Xeon, OSX 10.4.11
    http://www.philipowens.com
    Jeremy Garchow replied 18 years, 2 months ago 3 Members · 4 Replies
  • Jeremy Garchow
    June 17, 2008 at 1:07 am
    Do you have a Kona card?
    Any chance there’s camera bars in the middle there somewhere?
  • Michael Gossen
    June 17, 2008 at 1:15 am
    Over Firewire or SDI? Trashed prefs?
    Michael Gossen
    Helium Digital Media
  • Philip Owens
    June 17, 2008 at 5:12 am
    Firewire only available, no Kona card. Prefs trashed recently, but worth trying again.
  • Jeremy Garchow
    June 17, 2008 at 5:19 am
    Bars?
    Also, you have to be sure that they clips were logged as 720p23.98. If not, try over riding the logged clip setting and capture again.
