Activity Forums Maxon Cinema 4D Material moving inside a logo
  • Material moving inside a logo
    Posted by Javier Lopez on November 18, 2010 at 1:04 am
    Hello,
    I just finished an animation, but when I preview, the material that I had applied to the object also moves inside the object, can someone please post any advise on how to make the material not move inside the object?.
    Thanks in advance.
    Javier Lopez replied 15 years, 9 months ago 2 Members · 4 Replies
  • Ronny Traufeller
    November 18, 2010 at 1:03 pm
    did you use camera projection or frontal mapping?
    zaid-ysap.de
  • Javier Lopez
    November 18, 2010 at 6:19 pm
    Hello Ronny,
    I am using spatial projection, I had tried the stick texture tag and all the different projection options, but nothing stops the material from moving, any other advice Ronny?.
    I appreciate your time.
  • Ronny Traufeller
    November 18, 2010 at 7:34 pm
    check if the texture offset is maybe keyframed. thats the last advice i have, otherwise you could share your file (maybe a stripped down version ) to have a look.
    greets
    zaid-ysap.de
  • Javier Lopez
    November 18, 2010 at 10:39 pm
    Hello Ronny,
    I had uploaded the video, please take a look to see what advise you can provide.
    Thanks again.
