Activity Forums Adobe After Effects Material / Flag effect?
  • Material / Flag effect?
    Posted by Lawrence Vaughan
    on September 1, 2005 at 1:03 pm
    Hi everyone,
    I have created a flag in photoshop and want to make the image move similar to a flag. it doesnt have to be amazing, just look like it is blowing in the wind.
    Anyone know how to do this? If i can create this effect without getting into heavy coding and by using the filters that would be amazing.
    any suggestions?
    many thanks.
    Lawrence
    Lawrence Vaughan
    replied 21 years ago
    3 Members · 3 Replies
  • Peter Stenhouse
    September 1, 2005 at 2:12 pm
    I have done similar effects by using the displacement map filter on the flag. As your displacemnet map select a layer of Fractal noise that you have precomposed, the offset of the fractal noise should be animated in the direction that you want your wind to go,use the luminance of this layer to distort the flag. With displacement, areas of 50% grey have a zero distortion, so for those parts of the flag that you want to be fixed use a grey solid with a feathered mask over the noise in your fractal noise comp (feathered to smooth the transition from static to moving parts of the flag). To give the flag some shadows, use the fractal noise comp over the flag with a composite mode like multiply or overlay, and then use a duplicate of the flag layer as an alpha matte, so that the shadows don’t exceed the boundaries of the flag. and I think that should work. Obviously there is a lot of tweaking in the Fractal noise to give you a flowing wind your happy with. Great. i’m not terribly good at explaining this sort of thing. Hope this works out, I am sure I have seen same technique in a tutorial on this site, tattered flag tut perhaps.
    good luck
    Peter
  • Serge Hamad
    September 1, 2005 at 4:30 pm
    Also check for “3D Flag” from Zaxwerks.
    Salut.
    Serge
  • Lawrence Vaughan
    September 2, 2005 at 8:28 am
    excellent. ill try both of those options. many thanks.
