Activity Forums Maxon Cinema 4D Material Anti-Aliasing Problem…
  • Material Anti-Aliasing Problem…
    Posted by Ryan Kehn on July 1, 2009 at 10:45 pm
    Hey All,
    Anyone have some suggestions for cleaning up my material renders? I’m using a high res targa in the color channel of my material, anti-aliasing is set to best, still-image but on my opening tight shot, the edges of the image in the material are still coming across a bit ragged. As the camera zooms out, it gets cleaner.
    I’ve gone through the different sampling modes and messed with MIP levels but am not too familair with what those settings actually achieve.
    I’ve attached a picture of the tight shot. The aliasing takes place around the gulf coast of the US on the map.
    any help would be greatly appreciated!
    Best,
    Ryan
    Brent Blaskievich replied 10 years, 10 months ago 3 Members · 2 Replies
  • Adam Trachtenberg
    July 2, 2009 at 2:21 pm
    Does the bitmap you’re using have enough resolution to avoid pixelating at close range? If not you won’t be able to overcome that in Cinema.
    If so, I suggest you place a compositing tag on the globe object and specify a higher AA level than the default Best setting.
  • Brent Blaskievich
    November 20, 2015 at 2:36 pm
    Raising the min from 1×1 to 2×2 for just that object with compositing tag fixed it. Thank you.
