  • Posted by Adrian Gordon on June 26, 2009 at 10:02 pm
    I have spent a littl e while digging around the forums for the answer, exhausted after 2 hours trying to figure it out and after a 10 hour day the brain is dead.
    I have been given a wipe, pair of scissors pass left to right. I have a fill with alpha channel and a matte to boot.
    From an Avid back ground I would struggle as I don’t use them every day but on fcp I am all at sea.
    Can any one advise
    I Have
    Scissor wipe (inc alpha)
    Scissor wipe Matte
    Ade
    Many thanks in advance
    Adrian Gordon replied 17 years, 2 months ago 6 Members · 9 Replies
  • 9 Replies
  • Kevin Monahan
    June 26, 2009 at 10:28 pm
    Simple:
    Content V1
    Matte V2
    Graphic V3
    Apply Travel Matte Luma to clip on V3
    Kevin Monahan
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
  • John Pale
    June 26, 2009 at 11:03 pm
    [Kevin Monahan] “Apply Travel Matte Luma to clip on V3 “
    Coming from an Avid background, you might not be aware of Compositing Modes, which Kevin is referring to. Just Right or Control click on the clip and select it.
  • Adrian Gordon
    June 27, 2009 at 6:19 am
    This bit I have figured out, neat effects. But which do I apply to what.
    V5 Fill travel matte alpha
    V4 Matte travel matte luma
    V3 Incoming
    V2 Matte with travel matte luma
    V1 outgoing
    This is the order of an avid setup but it isn’t working here and has blown my brains.
    Any ideas?
    Thanks in advance
    Adrian
  • Ed Dooley
    June 27, 2009 at 2:13 pm
    Mate Wipes, they go with Depends, don’t they? 🙂
    Ed
  • Adrian Gordon
    June 29, 2009 at 8:47 pm
    Hi Kevin
    Thank you for responding to my post.
    It certainly is a different mind set to an Avid. Normally the matte goes above the outgoing and above that another matte goes above the incoming but inverted (or visa versa).
    I have managed to get the wipe to work using a combination of luma travel matte and Image Mask I almost get it to work but I have a black & white layer.
    It’s doing my head in. The wipe needs to exit one image and bring in another so the matte needs to be used above each image surely?
    Still all at sea so thanks again in advance.
    Adrian
  • Adrian Gordon
    June 29, 2009 at 8:51 pm
    My spelling is bad I will admit but what conversation are you having?
  • Ceri Payne
    July 13, 2009 at 8:22 pm
    does this help? I think you can drop your matte into a gradient wipe:
    https://www.geniusdv.com/weblog/archives/utilizing_gradient_wipes_in_final_cut_pro.php
  • Mitch Zuleger
    July 23, 2009 at 9:22 pm
    I was having the same issue and was able to piece it together.
    V5 Fill travel matte luma
    V4 fill matte (grayscale, no alpha channel)
    V3 outgoing travel matte luma
    V2 wipe matte (grayscale, no alpha channel)
    V1 incoming
    This setup worked quite well for me.
  • Adrian Gordon
    July 23, 2009 at 9:52 pm
    Many thanks for your response. Yesterday I stumbled upon another way.
    V4 wipe with composite mode Add
    V4 Outgoing with Composite travel matte luma applied
    V3 Matte
    V2Incoming with Composite travel matte luma applied
    V1 Matte
    Bonkers but it worked. My client hired another editor today and when she said to him ” It’s working on FCP!” he said “Don’t worry, you can’t blame the editor.” It’s not a bad piece of kit it just a flawed buggy shit piece of software!
    Love it!
