Activity Forums Apple Motion Matchmoving a scene from different cameras
  • Matchmoving a scene from different cameras
    Posted by Anubhav Gupta on April 2, 2014 at 5:20 pm
    I am an intermediate after effects user. I’ve come across many tutorials that show how to matchmove (or 3d track) a scene using after effects, bojou, mocha, etc.
    But how does one seamlessly integrate a 3d element into a scene when there are more than 1 camera set up in the real world (i have 2 videos of the same scene from 2 different angles)?
    How do I calibrate the the scale and exact position of the object in 3d space. I can track the 2 angles of the scene separately in after effects using the 3d tracker. But even though i am successful in integrating the 3d object into the scene from both angles separately, it does not look right when the camera switches from one angle to another.
    I basically want the object to remain in the same 3d space with the same depth of field, lighting, etc.
    Hope what i am trying to say is clear to you.
    any help is greatly appreciated.
    Thank you
    Mark Suszko replied 12 years, 5 months ago 3 Members · 2 Replies
  • Robin S. kurz
    April 3, 2014 at 7:07 am
    I think you may have meant to post this elsewhere, no?
  • Mark Suszko
    April 7, 2014 at 8:02 pm
    Assuming you want to do this in Apple Motion, the CAMERA controls allow different focal lengths and settings for things like depth of field, and these are even somewhat keyframe-able. You can make more than one camera instance in Motion as well, so one takes over from another, based on the timeline..
