Activity › Forums › Apple Final Cut Pro Legacy › Matching white balance between shots
  • Matching white balance between shots
    Posted by David Cooke on July 12, 2007 at 9:20 pm
    Can you call up 2 clips next to each other and ‘match their white balances”. Example:
    if one camera was ‘off’ a bit from the main camera, does FCP have an ‘eyedropper’ function
    where you can “pick up” the white you like in clip #1 and then apply those settings to
    clip #2 to have it match? Here I am not referring to copying and pasting “attributes” like
    a color correction filter. Fellow FCP editor of Wedding videos wishes to more closely and
    easily match videos from 2 different mini-dv cameras.
    FCP Studio 2, MacBook Pro- 1 month old.
    David Cooke replied 19 years, 2 months ago 3 Members · 3 Replies
  • Shane Ross
    July 12, 2007 at 9:27 pm
    The function you are looking for is called MATCH HUE. You can make the whites match, or fleshtones, or if both cameras have the same wall or building in a shot. Look and see if the manual has this, and if not, then there is a great DVD on Color Correction that covers this, as it requires a few steps and is something that needs to be seen..can’t describe it well.
    If you can’t find it in the manual, here is the DVD that covers this:
    https://www.rippletraining.com/color_correction_for_final_cut_pro_.html
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • James Reid
    July 13, 2007 at 1:57 am
    This might work for you.
  • David Cooke
    July 13, 2007 at 12:10 pm
    Thanks guys. I’m fairly “young” in FCP experience. At my television job, we are in the process of replacing an older “Accom AFFINITY” NLE with 2 FCP systems. we’re still learning with the books and “playing” around a bit until all the pieces get shipped in, but
    and so far “blown away with the things that can be done, and “we haven’t even touched MOTION 3 YET. We’ve got so-oo much to learn!
