Activity Forums VEGAS Pro matching up audio
  • matching up audio
    Posted by Godfather on December 27, 2005 at 5:13 am
    i have two audio sources and i’m trying sync them up. but i cant seem to get them line up exactly. They are barely off but just enough that you can hear a echo. When i try to slide them together the clips “jump” to far in either direction. Is there a way to be able to move the clips with greater precision??
    -scott
    Edward Troxel replied 20 years, 8 months ago 5 Members · 4 Replies
  • Gary Kleiner
    December 27, 2005 at 5:49 am
    Turn off Quantize to Frames (top of the Options menu).
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Stephen Mann
    December 27, 2005 at 6:50 am
    And turn off “enable snap”
  • Gary & yvonne
    December 27, 2005 at 7:15 am
    I can never tell when I look at Quantanize to Frames, wheathers its off or on …it always looks the same.
  • Edward Troxel
    December 27, 2005 at 2:31 pm
    It’s easier to tell if it’s on or off if you look at it under the VIEW menu.
    IF you turn it off, make sure you ONLY adjust the audio off frame and not the video. That’s the reason for quantize to frames – to keep the video straight. Also make sure you zoom in on the timeline. It seems very unlikely that you’d hear echo on a half frame (that’s 1/60th of a second!) Make sure you’ve zoomed in on the timeline to see exactly how far apart they are. At the default view, it could look the same and still be 4 or 6 frames off. Then it’s VERY noticable. I usually fine-tune positioning using the 1 and 3 keys on the numeric keypad.
    Edward Troxel
    JETDV Scripts
