Activity Forums Apple Final Cut Pro Matching trims between two segments
  • Matching trims between two segments
    Posted by Ray Butler on April 29, 2020 at 8:56 pm
    Camera position is exact in both. Is there a calibration to ensure the two vid segment background dimensions are the same in order to allow the transition flow feature that minimizes jump cuts ? Instead of voice seaming, I am doing it with piano fingers, Problem is the body movement other than fingers is too pronounced to allow the transition flow to work. I would be trimming part of the two segments close to the point in time where the jump cut is.
    Ray Butler replied 6 years, 4 months ago 2 Members · 2 Replies
  • Kathy Murphy
    April 29, 2020 at 10:26 pm
    There’s a handy little plug in called mMorphCut which may help you out.
    It does a morph transition.
  • Ray Butler
    May 6, 2020 at 4:19 pm
    Kathy, thank you for the suggestion of using mMorph cut. Is this better than the built in transition flow in Final Cut Pro? Also if you may know, what are the limits when using final cut to speed up a video ,e.g 10% and still keep original pitch, without the audio being apparent it is out of sync the the sped up vid? It may be more noticeable for what I am using it for – solo piano pieces.
    And I need to keep the audio quality very good. I record the audio and vid at the same time , so it’s in synch . Thank you
