Activity › Forums › Apple Final Cut Pro Legacy › Matching Source Video in a 3 Camera Shoot
Posted by Robert Wright on February 14, 2009 at 10:51 pmI’m running FC Express HD. I working a project that is sourcing a 3 camera shoot. I’ve laid the 3 clips into the sequence, but I want to match brightness and contrast levels for the three cameras. How do I do that?
Thanks in advance.Thanks…
Rob
David Roth weiss replied 17 years, 7 months ago 3 Members · 4 Replies -
David Roth weiss
February 14, 2009 at 11:13 pmThat is typically done after the fact.
Cut first, then color correct one shot each from your three cams, then copy the CC to all other shots from that cam using the copy and paste attributes command. A very useful, but little known trick for that, is to use the “Find all” command to select all clips from each camera (i.e Find All with Camera-A) and apply the CC to all the highlighted clips at once.
Here’s a great tutorial from Digital Heaven’s Martin Baker that explains the Find All procedure really well: https://www.digital-heaven.co.uk/hot-tips-ep-7 .
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
Don Greening
February 15, 2009 at 8:14 pmHow the heck did I miss that one? *smacking forehead* David, For some time now I’ve been Cmd-selecting clips from the same camera in a multiclip timeline in order to paste attributes. Since there are usually 3 separate angles in my multiclips and they sometimes last upwards of a hour each this “selecting all the same camera cuts” can take awhile. By using the “find all” command instead you’re probably going to save me a ton of time during the next edit.
And I thought I’d seen all of Martin’s toots. Thanks, David.
– Don
David Roth weiss
February 15, 2009 at 10:33 pmI am a walking, talking load of trivia — and always happy to help you Don.
David Roth Weiss
Director/Editor
