Activity Forums Apple Final Cut Pro Legacy Matching settings, still have to render every clip.
  • Matching settings, still have to render every clip.
    Posted by Diego andres Delfino on June 18, 2012 at 11:49 pm
    Hi everyone!
    I am writing about something that is driving me insane. I am setting up a new default project in Final Cut Pro, and importing video files to it. Whenever I try to place one of these imported clips into the sequence, FCP asks me if I want the sequence to match the clip, and I say yes. When I check the sequence properties, they match the clip’s properties. Yet, when I try to import the clips, I have to render them every time, as if the formats did not match. What am I doing wrong?
    The video in question is in NTSC CCIR 601, H.264 codec, 873×480, 23.98 fps. I’m running FCP 7.0.3.
    Help, please! Thanks in advance.
    Mike Caddell replied 14 years, 3 months ago 5 Members · 5 Replies
  • Jon Smitherton
    June 19, 2012 at 3:18 am
    You have to transcode the H264 clips to Prores.
    Jon
  • Steve Eisen
    June 19, 2012 at 3:40 am
    [Diego Andres Delfino] “The video in question is in NTSC CCIR 601, H.264 codec, 873×480, 23.98 fps”
    Your sequence and footage needs to be an FCP friendly editing codec. ProRes is what you want to convert your clips to.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Creative Pro Users Group
  • Michael Gissing
    June 19, 2012 at 3:51 am
    And you need to chose a standard editing frame size. Your footage is actually 720 x 480 anamorphic SD so convert to that in ProRes 422.
  • Diego andres Delfino
    June 19, 2012 at 9:06 pm
    Thanks to all for the answers! What should I use to convert it? It’s a drag to have to render every time…
  • Mike Caddell
    June 20, 2012 at 5:09 pm
    Compressor.
