Activity Forums VEGAS Pro matching frames
  • John Rofrano
    May 5, 2015 at 11:47 am
    [Mike Kujbida] “Encode set to AC3;
    Click on Custom tab;
    On the first tab, set Dialog Norm at -31 (this sets it at unity gain);
    On the last tab marked Preprocessing, set the Line Mode Profile and RF Mode Profile mode to “none”;
    DC High Pass Filter On (this operates at <=3Hz and takes DC bias out of the mix);
    Bandwidth Low Pass Filter On (this takes aliasing noise at >20kHz out of the encode).
    Save this as a preset.”
    What Mike said… 😉
    It’s too bad Vegas Pro doesn’t come with this preset because it’s the first preset I make every time I set up a new system for DVD authoring. AC-3 audio is always too low until you turn off the profiles and adjust the normalization.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Luigi Perrotta
    May 5, 2015 at 3:00 pm
    Thank you Mike,
    I think this is it! I think I did this a few years ago and it worked.
    I will try and let you know how it works.
  • Mike Kujbida
    May 5, 2015 at 3:15 pm
    You’re welcome Luigi. As John said, this is one the first presets I create on a new machine because I use it all the time during DVD file creation.
  • Luigi Perrotta
    May 7, 2015 at 5:17 pm
    Thank you Mike,
    This worked well, it got as loud as I wanted.
    Before rendering I also applied an AUD Maximizer and a Limiter.
    I saved the preset.
    Luigi
  • Mike Kujbida
    May 7, 2015 at 7:38 pm
    You’re very welcome Luigi. Glad I could help.
Page 4 of 4
