Activity Forums Adobe After Effects Matching dv compression
  • Matching dv compression
    Posted by Jeff Russell on December 10, 2008 at 3:04 pm
    Hey Everybody,
    I’m working on a project where I’m putting nice, clean, sharp graphics into some dv footage and it looks very cg. If I were working with film I would add some grain so it looks like it’s in the scene, but the footage isn’t grainy, it has horrible dv compression. Does anyone know a way to match dv compression or some way to fake it? The footage was shot DVC PRO.
    Jeff Russell replied 17 years, 9 months ago 2 Members · 2 Replies
  • Andrew Bardusk
    December 10, 2008 at 6:25 pm
    If you have Saphire plugins “Jpeg Damage” would be worth considering.
    Another thing you can do is create a gray solid, with all color and saturation set to 0 and brightness set to 50(if I recall correctly).
    Then put a “noise” effect, turn it to 100 percent.
    Then set you gray solid do “overlay”
    Then adjust the opacity, and scale to make it look like big chunky compression.
  • Jeff Russell
    December 11, 2008 at 5:26 pm
    Thanks. I’ll give that a try.
    Jeff
