Activity › Forums › Apple Final Cut Pro Legacy › Matching Clip Format with Sequence Settings: What am I doing wrong?
  • Shane Ross
    January 12, 2008 at 7:39 am
    NO, they are not. Clip settings are 720×480…sequence settings are 720×540…PAL dimensions…but NTSC frame rate.
    CHoose the DV/NTSC EASY Setup…create a new sequence.
    Shane
    Littlefrog Post
    GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
    http://www.lfhd.net
  • Evan Taylor
    January 12, 2008 at 3:05 pm
    Thanks Shane! It worked, I don’t know how I didn’t get it to work before. I used the higher dimension because i thought it created a letterbox. I appreciate your help.
    A thousand blessings.
    -Evan
