Activity Forums Adobe After Effects Matching audio with graphic movement?
  • Matching audio with graphic movement?
    Posted by Cody Silva on August 4, 2005 at 4:25 pm
    Is it possible to sync an audio track to affect a graphic element. For example…..if I have a naration audio track and want to animate a mouth so it looks like the person is actually moving their mouth at the same time the words are being said. Is there some way other than frame by frame manipulation to make this happen? Some filter or expression that will move the graphic (mouth) according to the highs and lows of the audio track?
    Ken replied 21 years, 1 month ago 4 Members · 3 Replies
  • Jeff Mullen
    August 4, 2005 at 4:37 pm
    Trapcode Sound Keys
    Cheers!
    -Jeff Mullen
    molek
  • Mcvideo
    August 4, 2005 at 6:48 pm
    trapcode.com look for soundkey plugin. watch the demo. It’s what you need.
  • Ken
    August 5, 2005 at 3:21 pm
    I think what you are wanting to do can be accomplished with the ‘convert audio to keyframes’ function and a simple expression.
    The only reason you would need soundkeys is if you had soundtrack where you couldn’t isolate the individual voice.
    Soundkeys is great – but if you don’t need to spend 90 bucks to get what you are after, that’s great too.
