Activity Forums Adobe After Effects matching 3D scale between comps
  • matching 3D scale between comps
    Posted by Malcolm Desoto on December 9, 2010 at 5:04 am
    issue 1:
    So, I’ve got a complex 3D light rig made up of a light ball and metal truss in one comp that I’m trying to plant on top of a building in another comp.
    When I drop the light comp into the comp with the building, I make it a 3D layer and hit the ‘continuously rasterize’ switch.
    From this point, it seems like the truss and light ball are in different 3D planes or something and I can’t seem to match them up.
    issue 2:
    I’ve tracked the motion of the footage and applied all of the tracking data to a null object. It works for everything within the comp, except for the 3D light ball comp…I imagine because it’s 3D. What do I need to do to be able to successfully track the 3D comp into my shot?
    Malcolm
    “The secret to creativity is knowing how to hide your sources.” –Albert Einstein
    Tudor “ted” jelescu replied 15 years, 9 months ago 2 Members · 1 Reply
  • Tudor “ted” jelescu
    December 10, 2010 at 9:12 am
    Post a few stills- it always helps to get answers faster. From what I understand now, it seems that you do not need to turn the light ball comp and make it 3D.
    Tudor “Ted” Jelescu
    Senior Compositor/VFX Artist
