Activity Forums Adobe After Effects MatchGrain alternative that works in 32bit AE?
  • MatchGrain alternative that works in 32bit AE?
    Posted by Adam Lewen on May 24, 2024 at 4:07 pm
    Hello!
    I am looking for a solution!
    I did vfx work in AE and the studio has bright clamping issues duo to the fact I have used
    MatchGrain to finish and polish the shots. (delivered as EXR sequences)
    MatchGrain supports 8 bits… So my rendered files are not as expected (32bit or at least 16)
    What is my alternative? I need a to get the grain back.
    Any tip will be greatly appreciated!
    Kind regards.
    Hector Vera replied 2 years, 2 months ago 2 Members · 3 Replies
  • Hector Vera
    May 27, 2024 at 3:16 pm
    One of the alternatives I found online to MatchGrain is the Digital Anarchy’s Grain Effect. Its a plugin that creates grain and noise and has many types of grain that you can choose from.
    You can also adjust the size, strength, and type of the grain. It’s compatible with both After Effects and Premiere Pro.
    You can download a free trial to test it for yourself so see if it works for you, if you do decide to purchase it, it will cost $199.
    Here is the link for more info: https://digitalanarchy.com/Flicker/main.html
  • Adam Lewen
    May 28, 2024 at 10:38 am
    Thanks for replying Hector.
    I am trying to make sure, going through the documentation of the plugin as well as some online tutorials, are you sure flicker free has grain possibilities?
    I have used that plugin a couple of years back with someone, for flicker reduction.
    Not sure I understand where the grain related capabilities there.
  • Hector Vera
    May 29, 2024 at 2:22 am
    Its possible but I only looked it up to have that possibility when I was researching your question, I have not directly used it myself but try it for yourself and see if it helps or not 🙂 Good luck!
