Activity Forums Apple Final Cut Pro Legacy matchframe to tape
  • matchframe to tape
    Posted by Ron Darby on September 18, 2006 at 10:12 pm
    Has there been any new tools or products that allows you to do a match frame to tape while printing to tape.
    While printing a half hour show I often get under runs late in the show or find a miss-spelled word. It would be nice to do a match frame a few seconds before the edit rather than starting over from the beginning. I have play around with FCP’s match frame to tape years ago but never got accurate results.
    I use to use Discreet
    Ron Darby replied 20 years ago 4 Members · 9 Replies
  • 9 Replies
  • Ron Darby
    September 18, 2006 at 10:18 pm
    Oh ya
    My system is:
    FCP HD
    G4 dual
    UV 1800 RS22
    the video is routed through a DSR-45 in and out via firewire to G4 and in and out component to 1800
  • Kevin Monahan
    September 18, 2006 at 10:22 pm
    You can insert edit on layback with Insert in Edit to Tape. Just enter the TC number you want to punch into in the TC entry.
    You just have to operate with pre-striped tapes is all.
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
    Pres. SF Cutters
  • Dean Sensui
    September 18, 2006 at 10:34 pm
    Hi Ron…
    Dean Sensui from “Hawaii Goes Fishing”.
    I’m guessing you’re working with George on his show?
    If so, I had to do the same thing recently. FCP can do a frame-accurate insert of just the video, which is pretty much what we ended up doing.
    Should you need help with this just let me know.
    Dean Sensui — http://www.HawaiiGoesFishing.com
  • Ron Darby
    September 18, 2006 at 10:50 pm
    Thanks guys
    I am experimenting with it now.
  • Dean Sensui
    September 18, 2006 at 11:48 pm
    Ron…
    If you have a Betacam deck, experiement with the timecode offset setting. That did the trick for me.
  • Ron Darby
    September 19, 2006 at 12:00 am
    I think thats what I was trying last time I attemped to do it, is there a magic # that works for 1800s
    Also how are you getting your video from the Mac to your 1800? Do you have a Kona card of some type or are you passing through a DV to anolog device?
    Right now Im getting “compressions do not match output” so Im checking all mt sequence, clips, and output settings.
    Aloha Ron
    PS I just got back from a year trip in Florida working on a PBS show, amd yes I am still doing the “Granny TV Mall” show.
  • Dean Sensui
    September 19, 2006 at 12:18 am
    Ron…
    I’m using a Blackmagic Decklink SP card for output from FCP to a UVW-1800 via component, and am using the 422 controller cable that comes with it. I’m also using this setup as a reference output for all my color correction/grading and audio work.
    My sequences for HGF are DV format since nearly all the material we currently shoot is in DVCam.
    A/V device is set for Blackmagic NTSC, 8 bit (720×486)
    Audio: Decklink Audio.
    Sequence preset is the stock “DV NTSC 48 kHz” preset.
    Here’s my setup for the 1800:
    Protocol: Sony RS-422
    Audio Mapping: 2 channels
    Time Source: LTC & VITC
    Port: RS422 Deck Control
    Frame Rate: 29.97
    Use deck search mechanism.
    Capture offset: 0
    Handle size: 00:00:00;00
    Playback offset: +00:00;04
    Pre-roll: 5 seconds
    Post-roll: 2 seconds
    Hope this helps.
    Granny’s a fun guy. Quite a character!
  • Bret Williams
    September 19, 2006 at 2:32 am
    [ron darby] “Right now Im getting “compressions do not match output” so Im checking all mt sequence, clips, and output settings.”
    You’re trying to insert edit from the timeline to the deck. Edit to tape works from the viewer to the tape. You’re probably trying to edit a slug onto the tape. Put the sequence in the viewer.
    Do a preview first just like the good ol tape editing days.
  • Ron Darby
    September 19, 2006 at 2:39 am
    That did the trick along with Deans info. It works great now
    Thank you all very much
    Aloha & mahalo
    Ron Darby
