Activity Forums Adobe Premiere Pro Matchframe Edit…
  • Matchframe Edit…
    Posted by Mark Pybus on September 9, 2009 at 4:00 pm
    Hello,
    I’m an Avid editor who is doing some work on Premiere CS4. I was wondering if there is a way to do what Avid refers to as a ‘matchframe edit’. Essentially it’s a button that quickly creates an edit point at a given location. Currently in Premiere, I have to activate the razor blade tool and zoom into the exact point in order to accomplish this. It’s awkward, because the razor blade tool doesn’t seem to snap to my playhead.
    Also, is there a way to save transitions as favourites?
    Thanks in advance!
    Chris Buttacoli replied 17 years ago 4 Members · 5 Replies
  • Jeff Brown
    September 9, 2009 at 5:17 pm
    I don’t have Premiere open, but I seem to recall it’s “Ctrl+K” (for ‘Kut’?); it should split your selected tracks at the playhead point.
    -jeff
  • Mark Pybus
    September 9, 2009 at 6:05 pm
    That doesn’t seem to work. You would think that there would be some way to do this within Premiere as it’s a pretty basic function.
    Thanks anyway.
    G5 Dual 1.8, 1.5GB RAM
  • Jonas Bendsen
    September 9, 2009 at 6:24 pm
    Ctrl+K is definitely the cut shortcut key combo. I use it all the time (rarely use the razor blade tool, because you have to zoom in so far to make a precise cut).
    Make sure your track is highlighted (click on the track’s name box), and you are working in the window with your time line/sequence or Premiere won’t know what you’re trying to cut.
    This is my life, I edit and edit and edit and edit…
  • Mark Pybus
    September 9, 2009 at 6:36 pm
    Ah, I had the wrong window highlighted.
    Thanks again guys.
  • Chris Buttacoli
    September 11, 2009 at 5:15 pm
    You can actually change or create your own keyboard shortcuts in the preferences menu. I use the razor alot as weel, and changed the shortcut from “ctrl-k” to just the letter “x”.
    Not sure how that would be called a matchframe edit in Avid though?
