Activity Forums Adobe After Effects Match3D layer position to camera view
  • Match3D layer position to camera view
    Posted by Pierpaolo Ferlaino on July 4, 2013 at 2:58 pm
    Hi. I’m animationg the camera in 3D space making a long slow movement.
    When I create a new layer and make it a 3D layer it obviously places itself in 3D space and disappears from the camera view.
    Is there a simple way to position it in front of the camera so I can easily match the position where it was created as 2D layer?
    Pierpaolo Ferlaino replied 13 years, 2 months ago 2 Members · 2 Replies
  • Ridley Walker
    July 4, 2013 at 3:26 pm
    You can select the layer and press the Control + Home keys on Windows or the Command + Home Key on Mac.
    That’s the shortcut for Layer >Transform > Centre in View.
  • Pierpaolo Ferlaino
    July 4, 2013 at 6:21 pm
    Yes, sure.
    I knew there was the “center in view” command somewhere and it was right under my nose… Maybe it was time to take a break.
    Thank you very much!
