Activity › Forums › Adobe Premiere Pro › Match source – lower bitrate ??
  • Match source – lower bitrate ??
    Posted by Paul Dougherty on December 8, 2014 at 7:30 pm
    I’m usually happy to work with the Export default “Match source – medium bitrate” but have been asked to make my Seq with an irregular size smaller for use in PowerPoint. A la Compressor I would love to make a copy of the preset “Match source – medium bitrate” rename it and tweak it, but how?
    When I try to improvise and make a Quicktime set to codec H.264 the Codec Settings button (in the Export Settings window) seems greyed out, any ideas?
    Thanks in advance for any suggestions.
    Paul
    P.S. Lacking in a solution and needing to output quickly I exported a Losseless mov and did m compressing in After Effects where I could fine tune the codec setting and dial down the data rate.
    Paul Dougherty replied 11 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
