Activity › Forums › Adobe Premiere Pro › Match Settings created unusable MPEG2 file
  • Match Settings created unusable MPEG2 file
    Posted by Maicol Ordoñez on January 11, 2012 at 9:24 pm
    Guys!
    I did the newbie mistake of exporting a sequence with the match settings option.
    This file is all I have of the project now and I have no clue what to do with it. I have a Snow Leopard MacBook Pro with the Adobe Suite and I’m stuck. All I get is a black video file no matter what I try to encode it to! Help!
    Robert Buncher replied 14 years, 8 months ago 4 Members · 6 Replies
  • Ann Bens
    January 11, 2012 at 10:05 pm
    Dont use match sequence settings in the export, you end up with the wrong codec.
    Use a preset or set everything manually.
    Adobe Certified Expert Premiere Pro
    Adobe Community Professional
  • Jeff Pulera
    January 11, 2012 at 10:09 pm
    Maybe run the file through Handbrake or something and convert to .mov?
    Jeff Pulera
    Safe Harbor Computers
  • Maicol Ordoñez
    January 11, 2012 at 10:42 pm
    I tried converting it through MPEG Streamclip to Apple Pro Res but it came out playing black video with audio. Is Handbrake the same as MPEG Streamclip or does it work differently? And if so what should I convert the video to?
  • Maicol Ordoñez
    January 11, 2012 at 10:44 pm
    @Ann. I wish I had to the option to go back and do it right this time but I jumped the gun and now this MPEG2 file is all I have.
  • Jeff Pulera
    January 11, 2012 at 10:52 pm
    I work on the PC and was going to mention MPEG Streamclip but did not because in order to work with MPEG clips you need to purchase some $20 QuickTime add-on (not sure if this applies to Mac), but maybe that is why it is not working? Never used Handbrake, but keep hearing about it.
    Jeff
  • Robert Buncher
    January 16, 2012 at 4:37 pm
    I think Jeff is on to something.
    When ever I have gotten black video along with audio it has been because I lacked the necessary codex for the video.
