Activity Forums Adobe Premiere Pro Match Sequence settings – Pre Pro 5.5
  • Match Sequence settings – Pre Pro 5.5
    Posted by Nik Read on August 11, 2011 at 7:40 pm
    Hi all,
    Have just come over from FCP7 to PP5.5 on the mac and need a little help. I use XDCAM EX footage and when wanting to master a sequence in the same format it was edited in i.e. ‘Match Sequence Settings’ it only gives me the option to render an mpeg file, not a .mov. I can’t then play that file in finder to check it. Is it possible to make .movs in this way, rather than choosing a different codec, which has resulted in strange things happening…? For example, a simple fade up of a title leaves the title blue until it has completely faded up – therefore this rendered file is of course useless.
    Can anybody help please, I just want to archive files in the same settings I shot them in. For my purposes, pro-res files are just too large. In FCP you just went File – Export- Use Current settings… and away you went. Is there an equivalent in PP5.5?
    Thanks in advance,
    Nik Read
    Chris Tompkins replied 15 years, 1 month ago 2 Members · 1 Reply
  • Chris Tompkins
    August 12, 2011 at 9:18 pm
    Do you have encore?
    You can open up your PP sequence in encore.
    Render out your master.
    Chris Tompkins
    Video Atlanta LLC
