Forums › Adobe After Effects Expressions › Match Properties Selection
Rodrigo Kermessi
December 28, 2022 at 1:42 pmHi friends! Hope you´re all doing good!
I´m trying to create a script that you can select layers and some properties and match the selection of the properties. I mean, all selected layers would have the same properties selected.
I´m almost there, it works great with: position, rotation, scale, opacity. But, doesn´t work with any other property.
Here is the script so far:
<b style="">var myComp = app.project.activeItem; //selected properties var myProps = myComp.selectedProperties; for (var p = 0; p < myProps.length; p++){ //selected layers var myLayers = myComp.selectedLayers; for (var l = 0; l < myLayers.length; l++){ // select matched properties for selected layers myLayers[l].property(myProps[p].name).selected = true <b style="">}};
Rodrigo Kermessi
December 28, 2022 at 2:49 pmPlease, ignore both <b style=””> not sure how it appeared there.
The right code (so far) would be:var myComp = app.project.activeItem;
\\selected properties
\\selected layers
\\select matched properties for selected layers
myLayers[l].property(myProps[p].name).selected = true}};
Dan Ebberts
December 28, 2022 at 7:04 pmTo do that, I think you have to build the property spec path on the fly, like this:
var myProp = myProps[p];
var myPropString = "";
while (myProp.parentProperty !== null){
var name = "\"" + myProp.name + "\"";
myPropString = ".property" + "(" + name + ")" + myPropString;
myProp = myProp.parentProperty;
if (myPropString != ""){
eval("var myActualProp = myComp.layer('" + myLayers[l].name + "')" + myPropString + ";");
myActualProp.selected = true;
Rodrigo Kermessi
December 28, 2022 at 9:13 pmHi Dan, thank you so much, it worked perfectly.
I´m a big fan of yours! It´s impressive that 99% of the thing that I had issues, like forever, about expressions and scripts for AE, was solved by you in some forum over the internet or even learning in the classic MotionScript.com. Legend!
PS: The first plugins I ever bought was TypeMonkey and MotionMonkey. 🙂
Best Wishes!
Dan Ebberts
December 28, 2022 at 9:50 pmThanks for the kind words! I appreciate it.
Log in to reply.
