Activity › Forums › Maxon Cinema 4D › match MOOOOOOOOVING
  • match MOOOOOOOOVING
    Posted by Nicholas Toth on January 31, 2007 at 6:42 pm
    So here’s the deal, going from boujou 3 to c4d is very painful for some reason.
    I matchmove it super quick with the wizard, and then output a .lws. All is well.
    But when I import to C4d, the scene is 30 seconds long — but the initial match move was only 7 seconds!
    I re-mapped the test match move in AE, and it matches up right — but its jagged from the time remap.
    Suggestions? Comments? Anyone else use boujou 3? Love the ladybug!
    Bounce replied 19 years, 8 months ago 3 Members · 3 Replies
  • Mylenium
    February 1, 2007 at 6:41 am
    Haven’t seen any matchmoving software in a long time and I’m still a fan of PFTrack, but I seem to remember that the LWS is not written properly from Boujou (it writes 1 fps instead of the actual footage frame rate). You need to edit it manually and adjust the scene fps. Should be no problem, since it’s text-based.
    Mylenium
    [Pour Myl
  • Nicholas Toth
    February 1, 2007 at 3:21 pm
    That does make sense. I’ll crack the code and post up the solution.
  • Bounce
    February 1, 2007 at 7:00 pm
