Activity › Forums › Apple Final Cut Pro Legacy › Match Frame to Source clip
Posted by Michael Kaidbey on May 21, 2006 at 6:21 amI searched for this but did not find a good answer.
I have a freeze frame in my time line and I need to match frame to the ORIGINAL clip that contains this frame and NOT the freeze itself.
Is there away to do this?
I promise not to say this is easy in Avid!
Ops!Thanks
Ron James replied 20 years, 4 months ago 6 Members · 11 Replies -
John Grote, jr.
May 21, 2006 at 6:31 pmGood day,
You need to double click the freeze frame so it loads in your source window, then use the match frame to find your original source clip.
Michael Kaidbey
May 21, 2006 at 7:51 pmHi
I tried that already and nothing happened.
Did you actually try this and it worked?
Or you think that is what should work?
I know that other applications do it this way! -
Wes Plate
May 22, 2006 at 6:16 amI don’t think there’s a way.
https://www.automaticduck.com/screenshots/MasterClipRefFreezeFrame.mov
— Wes Plate
Automatic Duck -
Michael Kaidbey
May 22, 2006 at 6:24 amThanks Wes
I beta tested the last version of your software and I want to thank you again for the opportunity.
Going back to the match frame problem, I think the only way is to use the clip name for the freeze which includes the time code and do it manually!
Not so good!
Michael -
Tom Wolsky
May 22, 2006 at 7:54 amBecause a freeze frame can be made up of multiple layers composited together there is no way for the application to call up a source file.
All the best,
Tom
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” DVD
Stevec
May 22, 2006 at 12:34 pmFrom what I can remember. when you make a freeze frame th eclip name that appears in the time line or viewer has the timecode ammended to it so if the original clip name is ” My Clip” the frezze frame would be “MyClip 3:05:15:05”
Hope this helps
Steve
Stevec
May 22, 2006 at 3:16 pmYeah, well all I can say is it’s not an Avid.
There are alot of things that is should do, but doesn’t.Steve
Ron James
May 23, 2006 at 12:31 amBuy an Avid, then… ;O)
You couldn’t drag me away from FCP.
G5 Dual 2.7 GHz
2 GB RAM
OS 10.4.6
FCP 5.0.4
QT 7.0.4
