Activity Forums Adobe Premiere Pro Match Frame Problems
  • Match Frame Problems
    Posted by Douglas Morse on July 8, 2011 at 11:57 pm
    I can’t get match frame to work. Coming from FCP, I just used to hit a key when the appropriate bit was in the record window and the whole clip would end up in the source window.
    I am using merged DSLR footage, but I’ve tried unmerged clips and they fail as well. Any ideas?
    Also, some of my clips are synced with 4 different audio sources, and some with three. However this means rolling edits don’t work correctly. Has anyone ever encountered this workflow before and have a solution?
    Thanks – Doug
    Gerrit Van dyke replied 15 years, 2 months ago 4 Members · 3 Replies
  • David Cherniack
    July 9, 2011 at 12:01 pm
    Make sure the track of the clip you want to match is the topmost highlighted. Then it should work with the M key.
    [Douglas Morse] “Also, some of my clips are synced with 4 different audio sources, and some with three. However this means rolling edits don’t work correctly. Has anyone ever encountered this workflow before and have a solution?”
    I haven’t tried this but you may have to select all the clips (or group them)for Rolling Edit to work with all.
    David
    AllinOneFilms.com
  • Robert Brown
    July 9, 2011 at 9:51 pm
    I’ve seen this to. On a project last night it simply wouldn’t work. I found the function in the menu and it was greyed out. Went to another timeline and it worked again.
  • Gerrit Van dyke
    July 13, 2011 at 6:12 pm
    Curious about this as well.
    What I’ve noticed so far is that when I’ve opened an XML file from FCP in Premiere, it opens great but I can’t seem to match frame back to my original files.
    When I import a file, and make a new timeline, it works pretty good.
