Activity Forums Apple Final Cut Pro Legacy match frame on new project does not work
  • match frame on new project does not work
    Posted by Enrico Parents on May 11, 2009 at 9:13 pm
    Dear creative minds
    I have a problem on a file project that takes 10 minutes to load, the project is very big and three months old, i think is in some way corrupted, I thought of copying all files and sequences to a new project but if I do so then match frame command does not work.
    the new project loads immediately.
    Any ideas?
    Enrico Parents replied 17 years, 4 months ago 5 Members · 5 Replies
  • Kevin Monahan
    May 11, 2009 at 9:23 pm
    What happens if you use the Media Manager to do this?
    Kevin Monahan
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
  • John Pale
    May 11, 2009 at 9:57 pm
    Try exporting the project as XML and then importing that into the new project
  • Jeremy Garchow
    May 11, 2009 at 10:18 pm
    Save and quit FCP. Duplicate your porject in the finder and then date it “Project_2009_05_11” or whatever.
    Open the original project and delete out some of the old sequences you don’t need.
    What else is going on in your project? Lots of multicam stuff?
    Give us a summarized rundown of what’s in your project.
    Jeremy
  • Peter Wiggins
    May 11, 2009 at 10:54 pm
    Normally a match frame won’t work because you don’t have the clip somewhere in your browser.
    Peter
  • Enrico Parents
    May 13, 2009 at 9:30 pm
    I found the answer of my problem, somebody connected an external USB hard drive to the keyboard and therefore everithing was going very slow, but still if I just copy all clips and sequences to another project then FCP is unable to recognize the original master with match frame…
