Activity Forums Apple Final Cut Pro Legacy Match Frame Multicam?
  • Match Frame Multicam?
    Posted by Kimberly Ruane on November 6, 2008 at 6:35 pm
    Hi all!
    Okay, so to match frame you select a clip in the timeline and hit f.
    However, most of our clips have been multiclipped.
    Is there any way to match back to the MULTICLIP itself (showing both cameras at the same time), and not just the master clip?
    Thanks so much!
    Kim
    Matt Gerard replied 13 years, 3 months ago 3 Members · 3 Replies
  • Kimberly Ruane
    November 6, 2008 at 7:36 pm
    Okay, I found out how to do this.
    But if anyone else needs the info:
    Park the playhead on the multiclip in the timeline.
    Select View -> Match Frame -> Multiclip Angle
    You can also map this to your keyboard.
    Take care!
  • Chris Chandler
    June 20, 2012 at 7:23 pm
    I know this is pretty dead by now, but FYI in case someone comes across this in a search like I did…
    You can map the “multiclip angle” command listed above to whatever your normal match-frame key is. It’ll match-multiclip for those, and it will function like a normal match-frame on non-multicam clips. No need to map it to an additional key
  • Matt Gerard
    June 4, 2013 at 5:03 pm
    nothing on the interwebs is ever dead! Just found this, thanks for the tip!
    Its more fun to ride a slow motorcycle fast than a fast motorcycle slow…
