Activity › Forums › Avid Media Composer › match frame link error
  • match frame link error
    Posted by Ludmil Kazakov on January 8, 2016 at 6:08 am
    Guys i have a movie and all MXF transcoded footage is in one folder.. there are some clips. like 20 minutes of it that cannot be matched to original clip
    “Could not select the clip XXXX in the last known bin location.. The clip may have been moved to a different bin”
    i search for the clip but i cannot find it..
    any ideas? i need to find the clip and change the source setting for the aspect..
    Ludmil Kazakov replied 10 years, 8 months ago 2 Members · 2 Replies
  • Glenn Sakatch
    January 9, 2016 at 4:42 pm
    Unless I’m mis reading your question, it sounds like you are asking us where you put your camera originals?
    Avid should tell you the last known path for the file that was linked. If the file isn’t there, then I’m afraid its up to you to go find a replacement.
    Or are you saying the mxf transcodes are offline?
    Glenn
  • Ludmil Kazakov
    January 9, 2016 at 5:49 pm
    i have a bin with transcoded media.. and not all media is in this bin.. when i try to match frame and find the file in bin i get error saying the original file has moved.. i have no idea where the original file is and i cant match back because it says the file moved.. and then when I try to search for it i cant find it.. but i do see it on the timeline…
