Activity Forums Adobe Premiere Pro Match frame kills I/O in Source Monitor
  • Match frame kills I/O in Source Monitor
    Posted by Steve Brame on October 9, 2014 at 12:15 pm
    I’ve usually been able to make a sequence out of a long clip, like an interview or a concert, and use the waveform to determine breaks in the interview or the beginning/end of a song, go to those points and Match Frame to load that spot into the Source Monitor, then set an In/Out point there in order to make a subclip. Suddenly, when I go to the start of a song or interview segment, Match Frame, then set an In point in the Source, then go to the end of that song or interview segment in the Sequence and Match Frame to jump to that point in the Source Monitor, the In point i just set is eliminated. That’s never happened before, and I’ve been using this workflow for years. I can’t seem to locate a setting that will make a In/Out point in the Source Monitor persist when Match Frame is selected on the same clip.
    Asus P6X58D Premium * Core i7 950 * 24GB RAM * nVidia GeForce GTX 770 * Windows 7 Premium 64bit * System Drive – WD Caviar Black 500GB * 2nd Drive(Pagefile, Previews) – WD Velociraptor 10K drive 600GB * Media Drive – 2TB RAID0 (4 – WD Caviar Black 500GB drive) * Matrox MX02 Mini * Adobe CC * QuickTime 7.7.5
    “98% of all computer issues can be solved by simply pressing ‘F1’.”
    Steve Brame
    creative illusions Productions
    Walter Soyka replied 11 years, 11 months ago 2 Members · 3 Replies
  • Walter Soyka
    October 9, 2014 at 9:39 pm
    When you hit F for match frame, it loads the current sequence clip into the source viewer with matching in/out points and sets the source CTI to match the sequence CTI. I didn’t think this was a new behavior.
    You may gang source and program (I’ve assigned this to Ctrl+Alt+G) to make your workflow easier.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Steve Brame
    October 9, 2014 at 11:55 pm
    Thanks Walter! I wasn’t aware that Match Frame picked up the In/Out points assigned to that clip in the timeline. Still, what I’m describing has never happened before, and I’ve been using the ‘technique’, silly as it may now sound, for years. I only have one clip in the sequence, and I’m trying to make many subclips out of it. Being able to set the I/O points in the timeline then Match Frame will make that easier.
    57 and still learning…
    Steve Brame
  • Walter Soyka
    October 10, 2014 at 12:01 am
    You know — forget what I said about ganging. There’s an easier way. Just cut/blade the clip on the timeline with Ctrl+K where you want the I/O points, then use F for match frame. Since the clip is cut, it’s match-framed I/O points will be what you want for your subclip extents. Ctrl+U and you’re done.
    Walter Soyka
