Activity Forums Apple Final Cut Pro Legacy Match frame in multilayered project
  • Match frame in multilayered project
    Posted by Toby Hinger on June 30, 2005 at 6:22 am
    Hi there,
    How do I match frame to the top layer in FCP? Say for the most part my edit is on Video Layer 1, so match frame is fine. Every now and then I have a couple of clips layered on top of each other on Layer 2, 3 etc. But the Match Frame function just matches to what’s on V1, even if that’s not actually visible.
    I’ve checked the manual, and tried combinations of modify keys.
    No luck.
    TIA
    Toby
    Tom Wolsky replied 21 years, 2 months ago 4 Members · 3 Replies
  • Kevin Monahan
    June 30, 2005 at 6:26 am
    Auto Select the track you want to match frame. In FCP 5, you can also select the clip w/o worrying about auto select.
    Kevin Monahan
    Author – Motion Graphics and Effects in Final Cut Pro
    fcpworld.com
  • Rob Forsythe
    June 30, 2005 at 11:58 am
    [Kevin Monahan] “In FCP 5, you can also select the clip w/o worrying about auto select.”
    Interesting.
    How much has the Auto Select been “de-emphasized” in FCP 5?
  • Tom Wolsky
    June 30, 2005 at 12:54 pm
    I think that’s the only change to autoselect isn’t it Rob?
