Activity Forums Adobe Premiere Pro Match frame from Source Monitor to Program Monitor
  • Match frame from Source Monitor to Program Monitor
    Posted by Joe Chow on January 6, 2012 at 9:15 pm
    I know the “m” command is good for matching frame back from a sequence to the source clip. But every now and then, especially when I’m cutting a long sequence or if I’m using the same material in 2 or more different sequences, I sometimes need to know where I’ve put a particular shot or soundbite in one of several cuts. In FCP, I can find the moment in my Viewer, hit the “F” button, and match forward to where it’s used in the Sequence (Canvas/Timeline), but I can’t seem to do that with Premiere Pro i.e. match frame from Source to Program/Timeline. Is this just a missing feature or is there a command I don’t know about?
    Joe Chow replied 14 years, 8 months ago 2 Members · 2 Replies
  • Ann Bens
    January 6, 2012 at 10:42 pm
    This clip has been used 4 times.
    Selecting one of the them will set the Playhead on the clip in question in the timeline.
    Adobe Certified Expert Premiere Pro
    Adobe Community Professional
  • Joe Chow
    January 7, 2012 at 12:30 am
    Not as precise as match frame forward for the instances I was thinking of, but this method works well, especially if the moment’s used multiple times, then it’s actually more effective. Thanks much.
