Activity › Forums › Apple Final Cut Pro Legacy › match frame can’t relink to audio
  • match frame can’t relink to audio
    Posted by Todd Carlson on November 15, 2007 at 10:45 pm
    we are editing with nested sequences and want to match frame back to the original clips on occasion so that we can bring in the audio from it. The problem is that the final cut pro source controls disapear for the audio once we match frame back to the clip.
    any ideas how to make this work? my editor says ‘it sucks when that happens’.
    Any advice appreciated!
    Todd Carlson replied 18 years, 10 months ago 2 Members · 4 Replies
  • Paul Escandon
    November 15, 2007 at 11:20 pm
    Are you going into the nested sequence to match the frame or using match frame directly from the sequence with the nest inside it?
    Why don’t you give rarely used Match Frame Source File command a try? It’s OPT+CMD+F – you can get to it by View > Match Frame > Source File. That should open the source media directly in the viewer and not the master clip. Not sure if this will work in a nest but it’s worth a shot.
    Paul Escandon
    Producer | Director | Editor
    Apple Certified Trainer – Final Cut Pro
    Oremus Productions
    http://www.oremusproductions.com
    Adjunct Professor of Media
    John Paul the Great Catholic University
  • Todd Carlson
    November 15, 2007 at 11:42 pm
    Yeah, weird. We’re trying that too. doesn’t help
    when we do either, the final cut pro source controls disapear for the audio once we match frame back to the clip. ….the little a1a2 which is next to the A1 and A2. They completely disapear.
  • Paul Escandon
    November 15, 2007 at 11:46 pm
    Is there also no tabs for Audio tracks 1 and 2 in the viewer when you match frame?
  • Todd Carlson
    November 16, 2007 at 12:18 am
    yeah, it seems to kill the tabs in both the viewer and canvas, source and record.
