Activity Forums Adobe Premiere Pro Match Frame Bug in CC
  • Match Frame Bug in CC
    Posted by Greg Janza on July 17, 2013 at 4:42 pm
    I’m wondering if others are experiencing this bug with the new CC version. Match frame seems to be broken with merged clips. It works fine with regular clips but I can no longer match frame to any merged clips.
    Would like to know if this is a random problem for some users or if most other folks are experiencing the same issue.
    Peter Garaway replied 11 years, 7 months ago 6 Members · 10 Replies
  • 10 Replies
  • Peter Garaway
    July 17, 2013 at 5:15 pm
    Hi Greg,
    Yes there are known issues using Match Frame on merged clips.
    You can find more info here: https://forums.adobe.com/message/5459364#5459364
    Sorry for the inconvenience. We’re working on resolving this.
    Peter Garaway
    Adobe
    Premiere Pro
  • Greg Janza
    July 17, 2013 at 6:17 pm
    peter-
    thanks for responding. I hope a fix can be released soon due to the inherent lack of editing efficiency by not having match frame capability.
  • Larry Asbell
    July 17, 2013 at 10:15 pm
    For me match frame is not working on Subclips.
    PP CC 7.0.1 (105), OS 10.8.3
  • Greg Janza
    July 23, 2013 at 12:07 am
    Hey Peter
    I noticed there’s an update to premiere pro but I see that Match frame is still not working with merged clips.
    Any update on when this bug will be addressed?
  • Peter Garaway
    July 23, 2013 at 12:29 am
    Hey Greg,
    There was a update released on July 10th which did address a Match Frame bug but not the Merged Clips bug that you are experiencing.
    Unfortunately I cannot give you a time on the next update but this issue is on top of the list.
    Peter Garaway
    Adobe
    Premiere Pro
  • Peter Sabatino
    July 29, 2014 at 11:16 pm
    Hi Peter,
    This is an old thread, but I”m hoping you are still seeing this. I’m going to try to reach out in other ways, but will try here first. There is a major flaw with Premiere when it comes to subclips, even in the latest 2014 version. You cannot match frame from a subclip to it’s parent master clip. This simple function is impeding my workflow. I am a professional editor and want to make the permanent transition to Premiere as I am unhappy with both Final Cut and Avid. I love many things about Premiere but this is a major hindrance. Is this something you are or can address?
    Thank you.
    -Peter
  • Peter Garaway
    July 29, 2014 at 11:49 pm
    Hi Peter,
    This is because under the hood there’s not really a master/slave relationship. Subclips are really just new master clips that have Subclip Boundaries set. If your using hard subclips, then switching to soft ones might be a solution–that loads the whole clip on disc into the Source Monitor rather than just the Subclip In/Out Range.
    Hope this is helpful. If this does not meet your needs please file a feature request here:
    https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform&loc=en
    Hope all is well,
    Peter Garaway
    Adobe
    Premiere Pro
  • Steve Brame
    January 28, 2015 at 2:48 pm
    [Peter Garaway] ” then switching to soft ones might be a solution–that loads the whole clip on disc into the Source Monitor rather than just the Subclip In/Out Range.”
    Actually, it doesn’t. I have a timeline full of ‘soft’ subclips, and Match Frame merely loads the subclip itself into the Source Monitor.
    Asus P6X58D Premium * Core i7 950 * 24GB RAM * nVidia GeForce GTX 770 * Windows 7 Premium 64bit * System Drive – WD Caviar Black 500GB * 2nd Drive(Pagefile, Previews) – WD Velociraptor 10K drive 600GB * Media Drive – 2TB RAID0 (4 – WD Caviar Black 500GB drive) * Matrox MX02 Mini * Adobe CC * QuickTime 7.7.5
    “98% of all computer issues can be solved by simply pressing ‘F1’.”
    Steve Brame
    creative illusions Productions
  • Dan Cooper
    February 4, 2015 at 11:53 am
    Hey Peter,
    Hope all is well.
    Is an update for this issues on Adobe’s agenda? This is a major setback in post workflow.
    Cheers,
    Dan
    dan
  • Peter Garaway
    February 6, 2015 at 5:00 am
    Hi Dan,
    This is not currently on the road map. If your goal is to match back to the master, a suggested workflow would be to make duplicate instances of the clip with different in and out ranges.
    We’ve added other features that help this type of workflow. If you have a long clip, say 30min, you can load the clip into the Source Monitor and use our KEM roll feature like a selects reel. See this video that speaks to the KEM roll feature: https://tv.adobe.com/videos/virtual-kem-roll.
    Another thought would be to put a sequence in the Source Monitor and use that as a selects reel.
    I hope these ideas are helpful to you. If none of these meet what you need please make a feature request here:
    Best,
    Peter Garaway
    Adobe
    Premiere Pro
