Activity › Forums › Avid Media Composer › Match frame Audio
Match frame Audio
Posted by Sarah Furie on September 5, 2014 at 5:45 pmHello,
Is there any way to match frame audio from a sequence and then “find bin” like you can with video?
Thanks.
Scott Cole replied 11 years, 11 months ago 3 Members · 2 Replies -
Michael Hancock
September 5, 2014 at 5:48 pmDeselect all your video tracks in your sequence.
Select the audio track that has the clip you want to match frame, and hit Match Frame, then Find in Bin.If it’s not important that you load that clip into the source monitor, hit Alt/Option+Find in Bin from the sequence and it will go straight to the bin and select that clip. No need to matchframe if you just want to find it in a bin.
Michael Hancock
Editor -
Scott Cole
September 6, 2014 at 11:28 amBetter yet, just right click on the track indicator light (I’m pretty sure it’s the record side indicator)and select “Match Frame.” You don’t have to turn off the other tracks.
M. Scott Cole
Senior Post Production Editor
60 MINUTES
CBS News, NYC
sc6@cbsnews.com
mscottc@comcast.net
