Activity Forums Avid Media Composer Match back to a Sequence
  • Match back to a Sequence
    Posted by Steve Rogalinski on October 9, 2014 at 4:08 am
    How do I match back to a sequence rather than an individual clip? I use a selects reel that has effected footage and I don’t want to match back to the original material.
    Steve Rogalinski
    Daniel Frome replied 11 years, 11 months ago 4 Members · 3 Replies
  • Shane Ross
    October 9, 2014 at 4:58 am
    You can match back to clips, group clips, multicam clips. You can’t match back to sequences. Sorry
    Shane
    Little Frog Post
  • James Patterson
    October 9, 2014 at 1:59 pm
    If all of your ‘effected’ footage is in the same sequence one option would be match frame to the master clip, open up the selects sequence and then reverse match frame to find it on the line.
    Not the most elegant solution but helpful if you have quite a large line of selects.
    Best
    Paddy
  • Daniel Frome
    October 9, 2014 at 2:00 pm
    [Steve Rogalinski] “How do I match back to a sequence rather than an individual clip? I use a selects reel that has effected footage and I don’t want to match back to the original material.”
    Load your selects reel into the source monitor, then use “reverse match frame” command.
