Activity › Forums › Apple Final Cut Pro Legacy › match back – audio
match back – audio
Posted by Joe Huggins on March 31, 2011 at 8:18 pmCow Keepers,
I have some HD media (film transfers) that I sync sound to in the timeline and then make subclips. This is for a feature. When the editor uses ‘match frame’ during the edit to find the original clip, it comes up MOS without the audio that was synced in the subclip. I know Avid has a way to merge the audio and video together when making a subclip, but is there a way to do this in FCP without having to render all new media on each take?
Thanks, Film Joe
Pradip Patil replied 11 years, 7 months ago 4 Members · 8 Replies -
Jerry Hofmann
April 1, 2011 at 10:17 amYeah, it’s called Merging clips…
You need to set in points in each clip where they sync. Then select “merge clips” from the modify menu. A new clip will appear in the browser which will act just like an A/V clip.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Joe Huggins
April 1, 2011 at 2:34 pmJerry,
Thanks for the reply, but I’m told that does not answer the key question. While we do have a merged AV clip, once you start cutting in the timeline and you select that clip by using ‘match frame’ to find the source clip, THAT is when the audio does not come up in the source window, it only shows the MOS clip for that take. This is a function used heavily in features.
Is there a way to be sure ‘match frame’ brings up the audio with the clip. Thanks for a clarification. Joe
Thanks, Film Joe
Pradip Patil
April 1, 2011 at 6:17 pmAre you sure that you are actually merging them using the merge clip command and not just syncing the audio on timeline only?
I don’t think that only lining up audio and video and then making subclips creates merged clips.
Pradip Patil
Mumbai,India -
Joe Huggins
April 1, 2011 at 7:57 pmPradip,
Thank you for clarifing, that is most helpful. We did test that and it works. However, I’m told it adds many steps. Since the film TC and audio TC are different, we have to first make a video subclip, then an audio subclip, then go to the browser window, select the 2 clips and create Merge based on In/Out.
I think Avid stream lines those 3 steps in one command. Do you know of any way third party software or other technique to reduce the number of steps to consolidate this faster?
Thanks, Film Joe
Pradip Patil
April 2, 2011 at 12:03 pmhttps://www.geniusdv.com/weblog/archives/merging_clips_in_final_cut_pro.php
Try this, I find this method useful. Fast and effective. All the timecodes are preserved and you can easily matchback to all source files.
Pradip Patil
Mumbai,India -
Joe Huggins
April 4, 2011 at 2:12 pmThanks Pradip, that might eliminate a step and extra keystroke.
Thanks, Film Joe
Lisa Cannon
January 20, 2015 at 1:08 pmThe link you posted no longer works – if it still exists and was simply moved, would you mind updating it? This is the workflow I’m researching. Thanks.
L
Pradip Patil
January 22, 2015 at 2:23 pm1. Sync the audio video files on a timeline
2. select each synced audio video and hit cmd+l, that links the file
3. Drag the linked clips back to browser in a separate bin.You can check the audio tracks tab to make sure that files have been linked.
You can create subclips, match back to all the source track etc etc..Pradip Patil
Mumbai,India
