Activity Forums VEGAS Pro Match Aspect ratio
  • Match Aspect ratio
    Posted by Donald Gibson on August 31, 2010 at 8:56 pm
    Ok I have a problem. Saturday I drop still pictures on the time line right at 90. I then Set the “ match aspect ratio” in the first picture. Under Properties/ Switch I then set the “reduce interlace flicker“ Click the next picture and “select events to end” and then “paste events attributes”. It work fine every picture was just right.
    On Monday I again dropped close to 150 pictures. I did the same thing again, as stated above. Only this time I did not get the same results.
    The 1st picture that I set up and copy is just fine. The second picture when paste from the 1st picture is just fine, but in the 3tr to the end I do not have “match aspect ratio”. I do have “reduce interlace flicker” all the way to the end.
    I can drop any picture from 1 to 150 and set the “match aspect ratio” I just cannot copy and paste. I am well aware that I have clicked something, but what I don’t know.
    Please help me. I just cannot think what it might be. I am working with Vegas Pro 8
    Don
    Donald Gibson replied 16 years ago 2 Members · 4 Replies
  • Aleksey Tarasov
    September 1, 2010 at 5:16 am
    What do you mean by “Match Aspect Ratio”. I believe it is “Maintain Aspect Ratio” switch or you talking about “Match Output Aspect” command in Pan/Crop window?
  • Donald Gibson
    September 1, 2010 at 5:25 am
    “Match Output Aspect” command in Pan/Crop window?”
    Yes this is the one I am talking aobut.
  • Aleksey Tarasov
    September 1, 2010 at 5:38 am
    Since you are working with Vegas 8 you don’t have the “Automatically crop still images added to timeline” option, which Vegas 9 has 🙁
    Paste Event Attributes copies the Pan/Crop settings “as is”, so if your images are different in size – they will NOT be matched to the project aspect ratio.
    What can you do? You can use scripts for this. For example, Vegasaur contains Match Output Aspect one-click command (and many other useful tools) that will do it for you. You can freely use it for 30 days.
  • Donald Gibson
    September 1, 2010 at 5:52 am
    Thanks Aleksey, this was giving me fits. I just could not understand the problem. You people are great.
    Thanks agian
    Don
