Activity Forums Adobe Premiere Pro Match 2 frames after tripod moved
  • Match 2 frames after tripod moved
    Posted by Firas Mikati on April 7, 2023 at 12:47 am
    I was taking a shot where the camera has to be still for a transition but it slightly moved. is there a way i could match the 2 frames?
    the change is very minor, changing the x axis seems to work, but then i have to scale to compensate for the aspect ratio.
    I’m sure there’s some sort of autoframe ai that can help but I’m not sure what to look for
    Hector Vera replied 3 years, 4 months ago 2 Members · 1 Reply
  • Hector Vera
    April 7, 2023 at 8:03 pm
    Perhaps matching the 2nd shot to blend on top of the first shot but saving it as a change for your second shot. You are working on frame animations in Premiere Pro? Also I believe scaling the 2nd shot if it was moved forward or move the position of the frame’s view under the x and/or y axis can help match the 2 frames. If that does not work, when you take the first picture for the frame again, take a 2nd one ensuring you do not move the tripod while pressing the shoot button on your camera. Maybe sending screenshots of the frames you are matching with can help me understand the issue even more.
