Activity › Forums › Apple Final Cut Pro Legacy › mastering to PAL: audio skippping, no image?
  • mastering to PAL: audio skippping, no image?
    Posted by Alan Langdon on February 8, 2011 at 2:16 pm
    SYSTEM:
    MacMini 2.4 GHZ, 4 GB RAM, FCP 6.06, DSR-11
    I have a project shot in HD 24 fps.
    I exported a reference QT and brought that into a DV PAL (anamorphic) sequence (settings: 720 x 576, CCIR 601 / DV PAL 5:4, anamorphic, DVCPRO PAL codec). And rendered the timeline, so I can print to tape.
    I am trying to master to miniDV, PAL anamorphic. But when I do so, opting for the PAL switch on the DSR-11, and when I try to play back / capture back (in Log & Capture) what I printed to video in FCP, I hear choppy audio and no image preview is available. I have checked the print to video settings (tried both DV PAL as well as DVCPRO PAL) as well as the capture settings (when trying to watch what I printed), but I can’t figure it out.
    Because I have no PAL monitor, I have no other way to check if the master is correct: the only way I have is to try to view it through Log & Capture, setting the input settings for PAL.
    The DSR-11 is connected FW400 via an external LAcie drive, which is connected to the mac via FW800.
    Any light on this issue?
    Peter Wiggins replied 15 years, 7 months ago 2 Members · 3 Replies
  • Peter Wiggins
    February 8, 2011 at 3:02 pm
    I’d check to see if you can layoff some straight DV material to the machine.
    Why dis you go for DVCPRO? You should be using a DV 25fps timeline.
    Peter
  • Alan Langdon
    February 8, 2011 at 3:43 pm
    Thanks for the quick response!
    So… it turns out to be a simple case of an old FW 4pin-6pin cable…
    I switched the cable and all is working fine now, using the DV PAL codec, not the DVCPRO by the way. Thanks!
  • Peter Wiggins
    February 8, 2011 at 4:03 pm
    Glad you got it working 🙂
