Activity › Forums › Apple Final Cut Pro Legacy › Mastering Sound in FCP 3
Posted by Dennis Cummins on April 22, 2005 at 10:07 pmhey guys wondering if anyone can help me out, ive just finished editing my project and im about to brun it on to dvd. just wondering is there anything i can do to master the sound, make it better than it already is, as the audio is a very important aspect of the project. cheers.
Dean Sensui replied 21 years, 5 months ago 4 Members · 3 Replies -
Thaxter Clavemarlton
April 23, 2005 at 2:58 am[dc] “is there anything i can do to master the sound, make it better than it already is”
Now THERE’S a broad question!
Let me just change a couple of words to demostrate the problem with responding:“Is there anything I can do to make my cake taste better than it already does?”
You see, there is a bit of information MISSING.
Back to YOU, dc.
Adam Schmidt
April 23, 2005 at 5:04 amIf you have the time and $$$, an audio post house will do a much better job than you will ever accomplish with the tools in FCP 3. Like Thax said, there are too many questions. Tell us your specific problems with audio for a better answer.
Adam
Dean Sensui
April 23, 2005 at 10:20 amYou’ve at least taken the first step: recognizing how important sound is.
As others have mentioned, there’s no simple answer to your question.
However, here are some things to consider:
— You gotta know what “good” sound is to know what needs to be done to get it.
— “Good” sound starts in the field, just like “good” video.
— High quality microphones and associated systems tend to get rather costly. Sometimes renting is a good option. Knowing how to use them really well takes training or guidance from an experienced pro.
— Having an accurate system to monitor the sound is an essential part of the process, and such systems are never cheap. I use a pair of Tannoys. If I had to do it again I’d get a pair of Genelecs.
— Often overlooked is the room you’re working in. Good speakers won’t perform well in a bad room. Consider the room as an integral part of the equipment.
— Some controls to consider: compression for some voice tracks. Equalization. Mixdown levels.
— Lastly, never mix on headphones. Always use speakers. Headphones will give you a false audio image and you’ll end up with a weak or inaccurate mixdown.
Dean Sensui
http://www.HawaiiGoesFishing.com
