Activity Forums Apple Final Cut Pro Legacy Mastering SD Footage for Broadcast & Archive
  • Mastering SD Footage for Broadcast & Archive
    Posted by Jonathan Clauson on April 20, 2010 at 1:57 pm
    Hello all!
    I am getting my feet wet with broadcast for the first time so I am still learning my way around the codecs and what not.
    What has been more or less the adopted defacto standard for archiving SD footage and for laying it off onto tape (MiniDV in this case) for broadcast. I have the tone bars, slate and SMPTE countdown so all is well in that regard, I just need some education on what the best way to archive/master. 🙂
    Thanks so much in advance all!
    Running Final Cut Studio 3 on an iMac with a SONY HVR-M15U HDV Deck. Thanks!
    David Roth weiss replied 16 years, 4 months ago 2 Members · 1 Reply
  • David Roth weiss
    April 20, 2010 at 4:05 pm
    DigiBeta would still be considered the gold standard for SD archiving to tape.
    However, do keep in mind that the DV codec ravages text and graphics, so after your edit is completed, you should always go into Sequence>>Settings and change the compressor to ProRes, then re-render the sequence. This will render using the ProRes codec rather than the DV codec, leaving your text and graphics pristine. Then, when outputting that to Digibeta you will have a vastly superior master.
    Keep mind, the video itself is not improved using the technique above, only text and graphics. But, the differece is very dramatic.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    EPK Colorist – UP IN THE AIR – nominated for six academy awards
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
