Activity Forums Adobe Encore DVD Mastering question regarding dual layer discs
  • Mastering question regarding dual layer discs
    Posted by Paul Allen on June 20, 2011 at 8:16 pm
    Hi all,
    It was my understanding that using encore I would be able to export a digital master (DDP) which could be sent to a replication facilility instead of the old system of using DLTs. Am I correct in thinking this, and is it possible with a dual-layer dvd? It’s not as clear as it could be in the help section. Just want to check before I start building the whole project in Encore.
    Cheers,
    Paul
    Avid Media Composer. PC with Intel DP35DP s775 iP35 ATX motherboard. Core 2 Extreme CPU QX6800 2.93GHz (4 CPUSs). 2030MB RAM. 256MB Nvidia Quadro/FX1500 PCIe
    Minu Sharma replied 15 years, 3 months ago 2 Members · 1 Reply
  • Minu Sharma
    June 21, 2011 at 3:52 am
    Hi ,
    Yes You are correct , DDP images can be created from encore and can be sent for replication.
    You can also create DDP for dual layer projects . In This DDP Image will have two folders for different layers .
    Select DDP image from encore build panel and create DDP from project , DVD folder or DVD image .
    If you want to set any copyright protection create DDP image from project itself.
    Minu
