Activity › Forums › Adobe Premiere Pro › Mastering and Exporting Broadcast Ready
  • Mastering and Exporting Broadcast Ready
    Posted by Kim Huston on October 17, 2007 at 2:57 am
    I’ve been told to master and export something to a dvd, high resolution for tv to comply to CCIR-601/ITU-R 601 NTSC broadcast specs, have peak audio levels between 10db and 8db.
    So I have two questions. First, is there an “effect” or something that I can put on my audio tracks to lower the sound so as to not go over 8dB, or do I have to adjust every piece of sound manually? It seems like I should be able to do it with the master track, but it won’t let me lower sound, only make it louder.
    And then for the video specs, what should I export that as? Do I need to change anything in the project, or is it just a matter of exporting to get it to comply? Should I plan to export it and then compress it later to fit on a dvd?
    My best guess is Uncompressed 8 bit YUV (4:2:2 YUV). I’m not really sure though. I’ve never had to export for regulation tv specs before.
    Darren Edwards replied 18 years, 11 months ago 5 Members · 6 Replies
  • Vince Becquiot
    October 17, 2007 at 3:10 am
    They are refering to video levels and saturation, but they may also require more specific encoding, timing, timecode, format, etc. My recommendation would to obtain the full specs from them and then contact a post house if you are not familiar with these terms. For example “high resolutio” means nothing unless a resolution is specified.
    As far as keeping the audio levels in range, you’ll have to look at the dynamics effect and make good use of the compressor. Again, a post house can probably handle this as well.
    Vince
  • Kim Huston
    October 17, 2007 at 3:23 am
    Those are as specific as they said, including that it should be either 4:3 or 16:9.
    I guess by high resolution they mean the highest you can give, but not 1080i, if that makes sense.
    It’s for a contest for a subsidiary channel of nbc, which I don’t think supports 1080i. It’s a satellite channel. But given that it was for anywhere between amateur and professional filmmakers, I think when they say “high resolution” they mean, “don’t give us the crummy low res file we requested for internet streaming originally”. That being said, I can either give them a 1280 x 720, which is what it was shot in, or a 720 x 486 for tv.
    My submission was shot in 24p, but will end up being 29.97 for the dvd.
  • Blast1
    October 17, 2007 at 4:18 am
    You might what to check want they want High Resolution and High Defination are two different things.
  • Kim Huston
    October 17, 2007 at 4:43 am
    I’m sending it tomorrow, so let’s say I’m going to export it at 720 x 486. What steps do I need to take from Premiere Pro to get it to adhere to those broadcast specs?
  • Jeff Brown
    October 17, 2007 at 12:04 pm
    For one thing, check the audio specs again. It is probably peaking at -10 to -8 dBFS (minus DeciBels Full Scale). Digital audio units don’t go above zero, but analog does. You should be able to add a compressor/limiter effect to limit the peaks.
    If you are not familiar with using waveform displays, the best thing would be to add a “broadcast limit” filter to the whole thing and hope for the best.
    Check your field order. (should almost always be lower first for NTSC).
    As you shot in 24p, check that you introduce pulldown correctly.
    Check what codecs they accept. I’m guessing they want a DVD-ROM, not DVD-video. Native QuickTime should be OK, but confirm. Apple Yuv is universal, as is Photo-JPEG. P-JPG at about 95% quality will save a lot of space and still look quite good.
    good luck with your submission.
    -jeff
  • Darren Edwards
    October 17, 2007 at 2:16 pm
    If you have Adobe Audition, a quick way to ready your audio
    for TV and film is the following:
    – Export your audio as one .WAV file.
    – Import it into Audition
    – Apply: Effects/Amplitude/Hard Limiting, and set a value
    of -8db (or whatever) in the automatically pre-selected top
    box ‘Limit Max Amplitude to…’
    – Save as .WAV and reimport back into PPro (or during your
    initial export keep the ‘add to project’ box clicked so it’ll
    automatically update itself in your asset palette).
    Whatever your audio app is, it’s a ‘limiter’ that you
    need to be looking for.
    Traditionally, -1.5db used to the norm limit for TV and -6db
    for film, although this is quickly changing now that people
    have replaced their rinky-dink portable TVs for 7.1 surround
    mega-cinemas capable of sub-bass frequencies, etc. It’s
    still a useful reference to work to though, and if they
    limits are slightly loud, then the broadcaster is usually
    capable of turning it down and conforming it for broadcast.
    Whatever you do, though, don’t ever rely on PPro’s
    ‘Broadcast Safe’ filter as an all-in-solution.
    Darren.
    x-gf.com
