Activity › Forums › Apple Final Cut Pro Legacy › mastering an hdv project
Posted by Stewart Charles on April 12, 2009 at 4:02 pmNow I’ve made the switch to Mac computers fcp and hd I’m planning on making a tape master at the end of the project and making a digital file to store on a hard drive.
How am I best to do this? I have projects that where filmed in hdv the sequence setting are set to proress for rendering. At the end of the project am I best to export the sequence as proress is this likely to be the most future proof?Stewart Charles replied 17 years, 4 months ago 3 Members · 5 Replies -
Walter Biscardi
April 12, 2009 at 4:10 pmYou can export a Self Contained ProRes Quicktime for your digital file.
If you lay that sequence back to HDV tape, you’re going to recompress it a second time in the HDV codec and the quality will definitely suffer. If you lay back to a higher quality format like DVCPro HD, HDCAM or D5 you’ll be able to retain most of the quality of the ProRes timeline
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
Chris Poisson
April 12, 2009 at 4:15 pmStewart,
HDV is lousy to edit in and worthless to archive in. Not a bad acquisition format, but a lot of us bail on the format by capturing to ProRes and/or/rendering in ProRes, and storing as digital files or laying back to a decent HD tape format.
Just my 2 cents…
Have a wonderful day.
Stewart Charles
April 14, 2009 at 7:39 amThanks for the info…
When I worked on dv at the end of a project Id make up a dv tape. I didn’t think about the limitations’ of the hdv format.
At the moment I can’t afford a better quality tape deck so I’m assuming im best to just make up a digital file?As for capturing straight to proress is this possible using a Mac book pro? Id had been advised to capture in hdv and set the render setting for the sequence to proress!
I feel like every thing is going wrong!!!
http://www.thin-kingmedia.co.uk
Chris Poisson
April 14, 2009 at 9:16 pmWhen I worked on dv at the end of a project Id make up a dv tape. I didn’t think about the limitations’ of the hdv format.
At the moment I can’t afford a better quality tape deck so I’m assuming im best to just make up a digital file?Just make a digital file, ProRes is fine.
Yes indeed, do it almost every day. I have a tutorial in here about how to capture to ProRes. But we do this daily on our MBP and towers.
https://library.creativecow.net/articles/poisson_chris/hdv-prores.php
Stewart Charles
April 16, 2009 at 9:41 amthanks for all the info! Ive got a few questions about the capture process and proress so Ill make a new post
