Activity › Forums › Apple Final Cut Pro Legacy › Master Templates Not Showing in Canvas
  • Master Templates Not Showing in Canvas
    Posted by Brian Leevan on December 1, 2008 at 8:20 pm
    When I go to Sequence, Add Master Template it loads into the viewer but I can not see any video. When I edit to the timeline I can not see any video. It plays but no video shows up. Also, when I try to save the project it says Operation Not Allowed. If I delete the Master Template from the Timeline then it will save the project.
    I’m using FCP 6 with Motion 3 on a Mac Pro using Mac OS X 10.5.4 with two 3 GHz Quad-Core Intel Xeon with 4 GB 800 MHz DDR2 FB-DIMM
    Ramon Aguilera replied 17 years, 1 month ago 2 Members · 1 Reply
  • Ramon Aguilera
    August 10, 2009 at 10:42 pm
    I have a similar problem.. First the Viewer and Canvas would show a blank screen with 6.0.1, that got fixed when i updated to 6.0.6. Now the problem is that the video WILL play in the Viewer but it will not play with all its effects in the Canvas. For example, the master template Fire-Mortise 1.NTSC.motn will play perfectly in the Viewer, but only the 45 degree gray strip line will show in the Canvas. Anyone know what i can do to fix this?
    Thanks guys.
