Activity › Forums › Apple Final Cut Pro Legacy › Master Templates in FCP7
Gabriel Cheifetz
August 8, 2009 at 8:41 amRob,
Do you have a 2nd monitor plugged in? Some of our users are reporting that a second monitor causes Master Templates to show up as white frames. If you have a 2nd monitor, try unplugging it and restarting. That might do the trick.
Gabriel Cheifetz
http://www.crumplepop.com | Master Templates for FCP -
Ulrik Brask
August 21, 2009 at 8:12 pmI am having the same problem on my system.
All Master Templates looks blank (white) in Final Cut Pro 7.
I usually have two monitors connected but disconnecting one of them has no effect on the problem.
The Master Templates will load when selected from the viewers generator pop-up,
and the control-tab will be displayed in the viewer, showing all the proper controls for the selected template.
But once I select the video tab in the viewer, all I get is a blank white image. Editing the template to the timeline changes nothing, nor dose rendering the sequence.
Opening the same template in Motion 4 works fine. The problem only exist within Final Cut Pro 7 and only concerns Master Templates. Ordinary motion projects works without problems in Final Cut Pro 7.
Final Cut Studio 3 was installed as an upgrade on top of an otherwise fully updated Final Cut Studio 2. The OS is updated to ver. 10.5.8, the hardware is a MacPro 2×3.0 GHz Quad-Core Intel Xeon, 8 Gb RAM, ATI Radeon X1900 XT graphics card.Any suggestions as to how this failure can be fixed would be most welcome.
Ulrik Brask
August 23, 2009 at 9:48 pmThe problem has been solved now! Removing the Magic Bullet Colorita FXplug-in did the trick.
I deleted the MBCC.fxplug and the MBCC_Slider.fxplug form the ~/Library/Plug-Ins/FxPlug folder and the GLCapsInfo.framework from the ~/Library/Frameworks folder and now the Master Templates renders in the Final Cut Pro viewer again.So be aware : The Magic Bullet Colorista plug-in from Red Giant Software has a conflict with the Master Templates in Final Cut Pro 7.
Ulrik Brask
August 23, 2009 at 10:42 pmIt turns out that I just needed to update the Colorista Fxplug-in on my system to the latest version. That one has no conflict with the drawing of Master Templates in the viewer.
Rob Chinn
August 25, 2009 at 5:09 amThanks for updating the post with what you found. This solution worked for me as well. Thanks!
