Activity Forums Maxon Cinema 4D master slider
  • master slider
    Posted by Michael Tannock on January 3, 2006 at 3:18 pm
    Does anyone know how to create a slider that can control the positions of many sliders, for instance a slider that is tied in to its own independent f-curve manager for tracking and controlling the positions of other sliders?
    Michael Tannock replied 20 years, 8 months ago 2 Members · 4 Replies
  • Chris Smith
    January 3, 2006 at 4:29 pm
    Create a null object. Create an Xpresso tag for it. In the Xpresso window. Drag in your user ‘master’ slider you made. Also drag in all other sliders you want controlled. Link the relavent parameters from the master to the slaves. Then obviously pipe this flow through math nodes or whatever you want. You can use a range mapper node so that where one the master slider moves a certain amount, it controls another a different amount.
    Also you can set this functionality up almost automatically by usiing the Set/Driven function of C4D. So that one thing controls another.
    Chris Smith
    https://www.sugarfilmproduction.com
  • Michael Tannock
    January 3, 2006 at 4:41 pm
    Many thanks for the quick response. What do you do however if the “slave” sliders exist within a PoseMixer tag?
    thanks again.
  • Michael Tannock
    January 3, 2006 at 4:55 pm
    So it doesn
  • Michael Tannock
    January 3, 2006 at 5:44 pm
    nope, I was right the first time, you can’t drag sliders into the Xpresso window.
